white spots in picture like snow screen
the screen is white snow but you can see the picture.
crwdns2889612:0crwdne2889612:0 11
crwdns2944067:038crwdne2944067:0
you've adjust the aerial/antenna/digibox? does it improve as the TV warms up? have you tried retuning?
My LG tv is doing the same thing. Teeny white spots in rows from top to bottom make the screen look crazy blurry. The set is a 42" and is barely 10 years old. Can it be fixed for a reasonable price and where?
Stephanie Dyer same as the original answer. Let us know what model your TV is.
Hey guys i have a problem on my LG Tv, some 12 large light circle's on my screen an i can't get rid of it
plss help me T-T
i have LG 32Lb5820-tb smart tv ,the display shows 12 white spot ,tell me how to resolve the problem
crwdns2934275:033crwdne2934275:0
Ron Zeeman, sounds like a DLP chip error. What model is your LG and consider posting an image of what the screen looks like with your question. Replacing the DLP chip and the DMD/formatter board in your TV should fix this.
crwdns2944067:017crwdne2944067:0:
I had purchase one LG 42" LED TV from Khosla Electronics Pvt. Ltd.(Kolkata Nagerbazar branch) on 9th June 2014. Invoice number is 3324/1415/02145. Make is LG 16108000004328 and Model no is 42LB5610. ATR 405PLVC008415.
from today morning its started showing one white cloudy round shape big dot on screen and by now its become 3 big dots on the same line. I tried to contact you over your both toll free number but failed. Can you quickly acknowledge my mail and give me a solution on the same
I too have a similar problem with my TV, a white bright spot appeared initially which became 3 spots on the same line when I touched that spot. Please help me with this problem.
Same like what Avijit described happened to me today. There was one white spot (nearly 2 to 3 inches radius and its now 3 spots in one line.)
i too have a similar problem, it is waste tv never buy LG products .
somewhere i found on the web that it is a problem of DLP chip on TV board and it need to be replace but repairing person want to make lot of money for such a small IC thats why they answers us randomly.
crwdns2934275:012crwdne2934275:0
Hi guys...
I no whats the actually problem is, its not that major actually the cap of led light of back light panel is off down. Because i have same problem so i add some links of that light of snow screen and second link of off down caps too ..
https://drive.google.com/open?id=0B3Q4rc...
crwdns2944067:08crwdne2944067:0:
Hi Krishna, i too facing same problem, please clearly explain how you cleared this problem
Hi Krishna, even I am facing the same issue, can you please take your time and explain the process for fixing it.
Thanks
Ashish
My LCD TV (42 inch LG 2014 model) has 4 white spots (top-down alignment).I have been given 2 different answers by two different Technicians. One says I need to change the chip board and the other says there is a problem caused by electro-magnetic radiation from wifi system
The same problem is showing in my TV 42LB 5820 model.There are 6 no of bright spots are located in two column at the center of the screen.This is merely 2 years of purchasing. It is really very disappointing. We are paying huge money for better quality but this is total failure.Company is doing serious offence with their customer. I would recommend not to buy any LG product.
It's a common problem with LG tv's. The reflectors on the backlight fall off. I made a video on YouTube on how to solve this under 1$
https://youtu.be/rLwHWLHT4T4
The solution for my problem was replacement of a part called array. This has multiple circular reflectors for backlight dispersal and these come off and fall down , which creates the bright spots ( I am no TV expert but that is my understanding). I got mine replaced and the problem was fixed. this problem seems to be very common for LG LB series most likely because of inferior manufacturing quality.
crwdns2944067:016crwdne2944067:0:
Thank u very much....I will check out what is array problem.... thank u for valuable information
How did you replace these arrays
LG technician came with replacement parts (basically strips with circular reflectors and replaced older ones), but it needed disassembly of the panel as the array strips are located right at the back of the panel. Cost was about Rs. 4,500.
Hey I am facing the same problem can u suggest me from where I can fix this problem and a tentative range in what i should pay them. I just have one white bright spot on the display screen.
Hi..I have also facing the same problem i.e a i inch round bright white spot on my LG 32LB5820 from today (27/04/2017). Anyone of you pls let me know how u people get rid from this problem.
crwdns2934275:011crwdne2934275:0
Hii sorry for not answering . just follow this link and your problem when be solved.
https://youtu.be/r8JX0nODs98
my lg 42l f6500 ,which is an expensive 3d tv purchased in 03-11-2016, having the same problem with white light patches increasing from one to three now. if i had read this blog earlier i wouldn't have gone for this wretched brand. contacted the lg service and they are already hinting at a huge service charge.
never buy an lg led tv- period.
augul2010@gmail.com
augul what have you checked? Do you plan on fixing it?
yes want to fix this prob
yes surely would want to fix this problem asap
Ron Zeeman crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 100,596
