Why does my oil light come on when the motor gets warm?
crwdns2942667:0crwdne2942667:0 3,473
You might want to make sure you are using a straight 30w, or heavier, oil and that the oil is not broken down by heat or contaminated by gas/solvent. If it is not the oil itself, then it could be the sensor (hopefully) or some bearing is getting loose enough to impact the oil pressure when everything's warmed up.
crwdns2934271:0crwdnd2934271:0 Noah Ackerman crwdne2934271:0
If you are using 20/50 and your oil level is within spec after it has been warmed up then you have an oil pressure issue. For a quick test, with the bike running, look into the oil tank. Do you see air bubbles and the oil moving? Another quick test: Place a pan under the oil filter > remove oil filter > start bike (it'll take 10 sec of run time). Do you see any oil being pumped out from the feed line into where the filter would be?
crwdns2934271:0crwdnd2934271:0 RJ Sours crwdne2934271:0
