The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
Beats pill not Charging
My beats pill is not charging. Can it fix?
crwdns2889612:0crwdne2889612:0 24
My beats pill won't work either I've been pretty rough on it and so when I plug the charger into the speaker I've accidentally pushed the metal part inside the pill and it won't charge
mine is in great condition but when i plug it in nothing happens and after 3 hours of charge it did not turn on
my beatspill has been broken for months and the metal part inside the charging part like moves around and when i put in the cable it just falls out! please help
crwdns2933315:07crwdne2933315:0
A very prevalent problem in lots of bluetooth speakers, including the Beats Pill. The micro-usb spec doesn't specify a robust enough attachment to the motherboard. Over the course of use, the jack is literally pushed off the PCB, sometimes (often) taking the traces off with it. The replacement of the micro-usb jack is very often not straightforward at all, particularly when the traces have been lifted off. If you have skills, it can be done, but if not........
I had a guy push the wrong charger In it it bent the pins just need parts looks like easy fix I ha VB e eltronic skills where do I find those parts
You'll want to troubleshoot the issue to narrow down the failed component.
  • First check your wall outlet, make sure it's providing power
  • Check the charging cable against another, known working, cable to verify that works.
  • Use canned air like Dust-Off to clear out any debris in the charging port itself.
  • Use the guide on our website to open up your device and replace the charging port if necessary.
MGOM. Bluetooth speaker trun off not properly
What you need to do is charge it as much as you can than turn it on after that hole the "b" button and the power button hold it the red light from the charging input will turn green and back to red three times
It should work after
Hi. I have done that but it won't hold charge at all do you have any other ideas? Thanks
My beats pill not charging
Where can I get it fix
If your Beats Pill isn’t charging, try the following steps to troubleshoot and potentially fix the issue:
  1. Check the Charging Cable and Adapter:
    • Ensure the charging cable is properly connected to both the Beats Pill and the power source. Try using a different cable or adapter to see if that solves the problem.
  2. Inspect the Charging Port:
    • Look for any debris or damage in the charging port. Use a soft brush or compressed air to clean it gently if needed.
  3. Reset the Beats Pill:
    • To reset your Beats Pill, press and hold the power button for about 10 seconds until the light flashes. This can sometimes resolve charging issues.
  4. Check the Battery:
    • If the battery is completely drained, it might take a few minutes of charging before the power indicator lights up. Leave it connected for at least 30 minutes.
  5. Update Firmware:
    • Make sure your Beats Pill has the latest firmware. Connect it to a device and check for updates if possible.
  6. Try a Different Power Source:
    • Plug the charger into a different outlet or USB port to rule out issues with the power source.
Phinisia Thomas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 44,892
