A handheld digital pet that was first sold in Japan in 1996.
My Tamagotchi is still not working after a battery replacement?
I put a new battery in but it is still not working, so what else can I do so it can work and be played?
Seriously, what is the gadget you're talking about? Are you sure that the problem is the battery only? Please complete questions so that you'll receive helpful answers.
set it on fire....................................................
Why won't my tomogotchi work?
crwdns2933315:07crwdne2933315:0
The mains problems with tamagotchis are :
  • oxidized pine (if you forgot the battery in it for 20 years ago… or buy it new. usually that’s not a problem with bandaï ones, but with odd pets) you can fix it by remove the rust with a q-tip with vinegar
  • bad contact from screen or battery . make sure the more screw you still have are well screwed.
Hope it will help someone
My tamagotchi is only 6 months old (the base). I had put a battery in, but it didn’t work still. I had put it in correctly and it still wouldn’t work. I had used a maxell battery
Not helpful whaler do you put it.
I suggest making sure you inserted the battery in the right direction. I know this sounds like a simple thing, but someone I know did a similar mistake and ended up throwing it away when the solution was so simple.
Find the hidden reset button on the back its there somewhere
Maybe reput the battery’s in if not get a box of new battery’s so it will work better 👏👏👏
this did not work! ahhhhhh
So this might be a bit obvious, but if your battery has a sticker take it off unless it says otherwise, because I didn't and i spent AGES trying to figure out what was wrong and then my dad came and took the sticker off and then it started working. So yea
Thank you. I did the same take the sticker off and it started working
Well mine wasn't also working and got super mad so I just threw it on the floor and then it worked again
Frog crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 95
crwdns2936753:030crwdne2936753:0 425
crwdns2942667:0crwdne2942667:0 12,928
