Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
Help figuring out what part should I be replacing
The USB data connection on my OnePlus One stopped working.
This means that no connection is even detected on any computer.
This is not a driver issue as the computer doesn't even notice anything has plugged in.
It's not a software/ROM issue because the same applies to fastboot mode and recovery mode - no data connection.
More facts:
1) When plugging to a computer USB port - the battery icon shows the charging (lightning) symbol for a half a second and disappears and it won't charge. The computer, of course, doesn't see a usb device plugged.
2) When connecting to an AC charger - it charges just fine.
3) I already tried replacing the dock connector and flat cable unit - did not solve the issue.
Any insight on this will be greatly appreciated!
Thanks
crwdns2889612:0crwdne2889612:0 -1
Have you tried to use a different usb cable for the computer? Your current cable may be damaged which could cause this problem. Have you tried plugging it in a different computer? The fact the ac charger works leads me to believe that the usb cable you have is faulty or possibly the usb ports on your computer. I would try a different usb cable first. I had to fix my usb cable a few weeks ago as I was having the same problem. Three out of four wires on my cable had to be resoldered to the micro usb connection. After fixing the cable I have no issues at all.
I tried different cables and different computers. It's not the cable. The cable works on a different OnePlus One phone.
Itay Nachum crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 92
