The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
Can my cpu be fixed
a capacitor fell off the cpu. can it be resodered?
crwdns2889612:0crwdne2889612:0 -1
Yes it can. You might want to check the value of the capacitor to be sure it is still good. I have had one drop off due to poor soldering. I was able to resolder it using a 25 watt soldering iron with a very small tip. I had to use regular 60/40 solder that melts at 360 degrees F. It worked. Just don't over heat the solder joint.
madruler crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 232
