It can be fix? (Battery connecting)
My Ipod's battery was dead so i bought a new battery for replace it. I removed old battery properly then tried to place new battery. Everything was good until i try to connect battery cable to motherboard with solder. There was too solder so i want to rip off. When i want to rip off this situation ocurred. It can be fixed? If is to be, i will get new one battery
Red, looks like you tore off the solder pads. First take another picture after you clean that mess. Then lets see those pads. This is some pretty heavy damage. If all the pads are gone, the only way to fix it would be to find other points on the board to connect the battery to.
I hope it can be fix http://i.hizliresim.com/3DLy65.jpg http://i.hizliresim.com/zA5dMO.jpg
O.K. I have the same issue too, I have the same model and I spent $50 used. It was someone elses and then they sold it to me like 3 or 4 owners ago. Apple really made a terrible battery for this and they won’t admit it, because FoxConn or someone else assembles it and then they sell it. Kinda weird. Anyway if you turn the iPod Touch 4th gen on, you will see the bulged battery behind the screen with the white bitten apple logo. It is a sign that the battery is bad. Do not use it then, it will only make it worse. I would know. I have the same issues. Also scratches, hopefully they can get buffed out. Also a dropped iPod Touch 4th Generation. The headphone jack and screen have a slight crack where you might be able to open it. Thanks for posting this issue. Cheers! and good luck to you!
Red crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 112
