How do I get the door ajar light to go off
All doors are shut but the door ajar light keeps coming on.
Update
Ford explorer sport track
Lonnie, the door Ajar switches are on the inside of the door (see attached diagram). To replace it you will have to remove the door panel, the water barrier etc. To determine which door has the problem, open each door with the key in the on position. The door that does not make a chime is the problem door. Remember that the drivers door makes a different sound. This video should help you with the door panel removal.
I have a 2005 Ford Explorer and my lift gate is constantly showing as ajar and it's not. Can you show me diagram like this?
I had same problem to on my 2014 Nissan Rogue. We found that bi accidentally shutting door and slamming your seat belt in door it will dent inside you door causing a poor connection with activation switch. We put 1/8 inch tape where the dents on door were to fill in dents and it worked no more problems to date. Jim
One of the sensors might be failing or broken. You'll have to open each sensor and check its connections to see if they are good. Then disconnect all of the sensors and test them one at a time and replace the one that isn't working.
EDIT: These images show what most of the door sensors look like on newer cars, they can either be on the car body where the door will press against it when closed or on the door where it will be pressed against the car body when the door is closed.
I am new to this where are the sensors?
They are in different places on every car, essentially they are like a little button that you can push in with your finger, on most new cars they are covered with a bit of rubber so they are not as visible.
They can either be on the car body or the door it self as well.
I will edit my answer to post a picture of what most modern sensors look like.
Thank You I will try that
My toyota hilux has these sensors. The problem is that if the car is turned off, the sensor will not detect that the door is already closed, hence I cannot lock it. But if the car is on, the sensor works just fine. What could be wrong?
Hi @ alvin_bontuyan,
What is the year and full model type for your Hilux?
My Mazda Tribute just had the same problem, it has internal sensors in the door latch. One door handle felt a bit loose, it would open the door and the lock would hold when the door closed but the handle still felt loose, so I checked this one first. On removing the inner door panel I could see a part not fully returning, so sprayed some WD40 on this and wriggled it till it it returned fully every time, taking the looseness out of the handle and fixing the light problem.
My 2011 Toyota hiace door open
Light is always on even though all doors are properly shut off. It started when i removed the bonnet and tried on a new one. What possibly causes this?
My 2014 Rogue had front driver door open, door locks were locking and unlocking. Took vehicle to Nissan dealership, they looked at driver door and noticed dents on door frame where the door contacts the activator switch, dents were caused by closing door on seatbelt, we filled dented area in with tape and it corrected the problem immediately…. maybe this could be your problem also…….. Hope it helps …. Jim
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 68
crwdns2936753:030crwdne2936753:0 250
crwdns2942667:0crwdne2942667:0 205,756
crwdns2944067:014crwdne2944067:0
I have a 2005 Ford fusion 1400cc
The door ajur light is on all the time and I can't lock the car with the remote I am assuming it's the light that is causing the problem can any body help please
crwdns2934271:0crwdnd2934271:0 Chris Lucey crwdne2934271:0
Hi @woodturner63 ,
Have you checked that all the doors (and boot) are shut correctly?
Open 1 door at a time and find the door light switch in the door frame (it may be under a rubber boot which you can leave on. It is spring loaded so you can push it in and it will come out by itself when you release it) and manually operate and release it a few times to see if you can make the light go on and off. Do this for all doors. Remember to only have 1 door open at a time when you do this.
If the light doesn't go out then you may have a faulty door switch or the wiring to one switch may have shorted out to the chassis. The trick is to find out which one.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
I have a 2008 ford edge and the door adjar light just came on today and started making a dinging noise, I have open the doors one at a time and shut one at a time and it doesn't go off. we just bought the car Monday and never had a problem with it then today it does this. can anyone help?
crwdns2934271:0crwdnd2934271:0 Samantha Jenkins crwdne2934271:0
Hi Samantha Jenkins,
If you have only just bought the car and if it was not a private sale, take it back to where you bought it from and show them the problem and ask them to fix it.
I have a Ford ranger 2007 and the door light turns on when I hit a bump or i
turn and then it turns off do I have a bad switch or bad connection ?
crwdns2934271:0crwdnd2934271:0 boss gaming crwdne2934271:0
crwdns2934275:09crwdne2934275:0
