Converting Internal MacBook Trackpad to External USB Trackpad
Hi there,
I have a "Apple MacBook Genuine A1278 MB466LL/A MB466 Silver Touchpad & Cable 821-1254-A."
It's the internal trackpad from a modern MacBook Pro. It has some kind of 22-pin connector on the end of the cable. Does anyone know if it would be possible to convert this trackpad into a standalone USB mouse that could be used on another computer?
Here's a similar hack for older model Macbook Pros: https://www.youtube.com/watch?v=dVQKl-HV...
Thanks!
crwdns2889612:0crwdne2889612:0 18
crwdns2944067:08crwdne2944067:0
Yeah I would Love to have a Tutorial or Guide for that, too.
So hoping for this to be possible.
Please, somebody help US....
@mayer, not to be too ignorant, but I fail to see how the link to that trackpad helps anything. Is it to verify the model?
I changed the icon to the correct machine. Then added the link so people would know exactly what was being talked about.
Hey,
I am also looking to achieve this mod. In my research I have found others used the test points on the older macbook pro touchpads as solder points for the data and power cables in USB. I cant see these at all on the newer A1278 models so will be sacrificing a known bad part to attempt to find them. Unfortunately this could be the only feasible option as the cables I the flex connector and cable are so %#*@ small. If I am successful will put it up for others to see.
crwdns2933315:08crwdne2933315:0
Yes you can! Mac trackpads and keyboards are just USB (1?) devices!
If you have a dead MacBook (Pro/ Air) you’ll still be able to convert its KYBD and trackpad to a genuine and original (although a bit steampunk) Mac KYBD & trackpad array. Apple itself, nor other brands IMHO have no KYBDs combined with trackpads on the market, So, get original!
Excellent addition for an iMac, for example.
You’ll need a soldering iron & some tools, as well as a simple USB A cable to spare.
USB 2 connections are very simple: Common, +5V, Data+ and Data -. Just 4 soldering connections to do.
The easiest Apple model to recuperate from I find is the 2007 MBP Core2 Duo with the defective NVIDIA 8600 M GT in it.
To be had for free, mostly.
Unrepairable, but the KYBD & trackpad may be salvaged. Internal flatcable may be defective (another generic defect with this model), but this in no way defeats our purposes.
If you want a more capable trackpad, a more recent Mac wreck will do. I hope some other iFixit members will chip in with the USB board pinout.
As for the present: see these:
https://youtu.be/dVQKl-HVnoI
https://i.imgur.com/IOur8lI.png
Happy DIY!
Of what Mac Mobo I don't know, but here goes:
https://bounav.files.wordpress.com/2008/...
I just did this with my 2008 MBP - different board layout:
https://photos.app.goo.gl/xi8sumh4anKHZc...
crwdns2947625:0crwdne2947625:0
crwdns2947517:0crwdne2947517:0
I was able to turn my old MBP keyboard/trackpad into a functioning USB device after seeing the YouTube linked above. I had a 2008 MBP with a different board layout. I looked carefully at the tiny traces and found DP, DN, 5VO, and poked around to find ground (it wasn't hard - you can see the ground-plane floods on the board).
Here's what mine looked like, and it works great - both trackpad and keyboard, including the special keys like brightness, play/pause, volume and mission control (on a Mac). [ edit - the trackpad does NOT work on linux incl RPi, but the keyboard does ]
FYI, the solderpoints are TINY and you need a steady hand to avoid hitting any components -- it was not easy and I definitely needed a magnifier and tweezers.
This worked great for me too, thanks! I used the trackpad from an early 2008 MacBook Pro and it was immediately functional as a pointing device once I connected it to my computer running macOS Sonoma.
However, multitouch didn't work! To fix this, I injected AppleUSBMultitouch.kext and AppleUSBTrackpad.kext from the OCLP project, and bam, multitouch, Trackpad control panel, everything just worked. Get the kexts here: https://github.com/dortania/OpenCore-Leg...
Hi, has anyone managed to do this? I’d like to try myself
I got a macbook but forgot the password how can i fix
If it can be fix how much do it cost
I got a hold on the new style of trackpad (started in 2016, I think) and the board schematic for a matching macbook pro. It looks like they moved to SPI for the trackpads, so I think you’d need to add another controller to convert it and at that point I don’t think you get the driver support.
Here’s some info for anyone that wants to pick up from here.
Interesting chips on the trackpad:
  • BCM5976C1 - There’s 2 and I think this is the digitizer and I think it’s i2c
  • STM32F103C8I6 - Arm Cortex-m3, capable of USB but IO is software controlled I think
Here’s the pin out for the trackpad connector on the logic board (I think you can ignore the KBD stuff since the keyboard uses a different connector):
  1. SMC_LID
  2. SMBUS_SMC_3_SCL
  3. SMC_PME_S4_WAKE_L
  4. SMBUS_SMC_3_SDA
  5. SMC_ACTUATOR_DISABLE_L
  6. KBD_INT_L
  7. TPAD_SPI_INT_L_CONN
  8. KBD_I2C_SDA
  9. GND
  10. GND
  11. TPAD_SPI_MOSI
  12. KBD_I2C_SCL
  13. TPAD_SPI_CS_L_CONN
  14. KBD_BLC_XBLANK
  15. TPAD_SPI_MISO
  16. KBD_BLC_XBLANK
  17. TPAD_SPI_MISO
  18. KBD_BLC_GSSOUT
  19. TPAD_SPI_CLK_CONN
  20. KBD_BLC_GSSCK
  21. PP5V_S4_TPAD_CONN
  22. KBD_BLC_GSLAT
  23. SMC_VIBE_L
then everything else is power or ground (5v, 3v, 0v - active gnd, 12.6v on a fuse)
This is great! Have you managed to do something with it? It's a massive challenge but I'm looking to turn one of these 2016-2019 15 inch trackpads into a standalone usb or bluetooth trackpad
Did you succeed, scoopy?
Hi guys,
I also looked for info about this mod
I would like to do this on the touchpad and keyboard of a 2011 macbook pro 17.
Were you able to do it?
I got a broken 2011 MBP for cheap and did that "conversion". You need the original motherboard for this and the keyboard and trackpad work as follows for me:
Long story short: It works in Windows (as "mouse" only, no gestures on the trackpad). In MacOS and Linux (tried Ubuntu) all gestures work out of the box as well. On Android_x86 it works if you connect it BEFORE booting Android (including gestures), if you plug it in after booting, the trackpad will not work.
On Android phones/tablets I can't get the trackpad working AT ALL (if anyone could help me I would be super grateful!)
Someone did it with a mid 2012 MBP (like a guy on hackaday) who described everything in greater detail: https://www.eevblog.com/forum/proje...ra...
If you also get a 2012 MBP that could be enough, if you get a different year model it's probably better to get the schematics online (somewhat easy to find on Google) like I did. Hope this helps you.
Hi guys
I got a 2011 macbook air (a1370 model) and want to do the same.
My connector and board look a little bit different. Anyone got ideas if this is feasible with my device or how to figure it out? Thanks!
looks like there is a kernel driver for the spi based touchpads, but would still require you to get the unit attached to your spi bus
https://patchwork.kernel.org/project/lin...
this may also be a good resource as it appears to be drivers for every trackpad version, but I believe assumes it is in an apple device
https://github.com/imbushuo/mac-precisio...
https://github.com/cb22/macbook12-spi-dr...
mitchchaiet crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 226
crwdns2942667:0crwdne2942667:0 13,656
