LCD display is dim at top (see pic) pbg4
Hi,
My 15" 1.0 ghz powerbook lcd display is showing some darkness or dimming at only the top 1/3 of the screen. The screen is still viewable and the performance of the machine is not impacted, but I'm wondering if you have any suggestions? Inverter, Cable, Backlight, or altogether LCD screen ?
I've linked some actual images taken from my phone so you can see the level of dimness that I'm referring to. Apologies of the lack of quality in the pics.
Thanks!
Screen Dim #1
Screen Dim #2
Screen Dim #3
Screen Dim #4
Screen Dim #5
Look closely and see if it's effecting 1/2 of the screen please.
it seems to be affecting approx 1/2 of the screen. See add'l images added to original.
However, once booted up fully into OS, it's not quite impacting half of the screen. You'll see what I mean by differences in #4 & #5
Looks like a failing screen backlight. I think you'll have to replace the LCD-panel. These things have two backlight tube in them and it looks like the upper one has given up the ghost. No way i know to replace just the tubes.
Yup, I agree with remac, its not an inverter or data cable issue cause then you would get no picture at all. You can probably replace these tubes, just do some research on Google. If not, just replace the display.
search tags I left - "half screen problem"
Clint Wagner crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,432
