Slow to brew and cup is not full.
My Keurig seems to be working fine without a K-Cup inserted. However with a K-Cup inserted, the coffee dribbles out very slowly and I only get 1/2 of a serving. I have to brew another smaller cup into the first one to fill my mug. I cannot find anything that is stopped up.
crwdns2944067:010crwdne2944067:0
I just cleaned my Keurig with white vinegar and got the flow of water coming out really well now, but only when there is no K-Cup or if I use the cup that you fill with your own coffee. I checked the little thing that pierces the bottom of the cup and that tube is clear (I was able to blow water through it with no problem). I'm not sure what else to try so that they machine can use the K-Cups... I have tried different K-Cups too and it has the same issue with them all. The water coffee just dribbles out...
crwdns2934271:0crwdnd2934271:0 Lyn F crwdne2934271:0
I have the same problem as Lyn F. Water flows fine until there is an actual K-Cup in the machine. I tried removing both the "washers" (rubber around the needles) and that didn't help...
crwdns2934271:0crwdnd2934271:0 keippala crwdne2934271:0
Have you tried changing the filter in the reservoir?
crwdns2934271:0crwdnd2934271:0 bradcole027 crwdne2934271:0
My solenoid is not turning off the bypass.
crwdns2934271:0crwdnd2934271:0 Keith howard crwdne2934271:0
Did all the things suggested at least three times no help! So I decided the pump was getting weak so I and bought a new keurig brewer....SAME PROBLEM!!
My wife suggested I buy brand X cups and I did...PROBLEM SOLVED...I think the grind is too fine in the Keurig cups and plugs the small outlet orifice!!
crwdns2934271:0crwdnd2934271:0 Jim White crwdne2934271:0
crwdns2934275:05crwdne2934275:0
