How do I replace my track pad button?
Mouse pad Button is stuck and I need a replacement, donor or otherwise. Please advise.
A less expensive answer if you want to go that way would be to simply use an external USB mouse. If the button is stuck in the on position you may need to disconnect the trackpad cable to operate properly. Ralph
I am using a new answer because I can't leave a URL in comment.
If you do want to replace the upper case here is a source. Ralph
For the record I tried three times to leave this as a comment but the program would not allow me to leave a "clickable" url. Ralph
So it isn't just me! If it happens to everyone I'll mention it on the uservoice
You would need to replace the upper case.
crwdns2942667:0crwdne2942667:0 3,247
