Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
gateway power on but screen stay black
power light come on but the screen stay black
crwdns2889612:0crwdne2889612:0 20
crwdns2944067:012crwdne2944067:0
Does the pc give a series of beeps when you turn it on? If so how many beeps?
no it does not beep
Yes 2 beep when powered up
Gateway lap top computer is on but the screen is black.
Yes it comes on! The screen just stays black
crwdns2934275:07crwdne2934275:0
“Blank/Black Screen” on a Gateway Laptop
Ridiculous problem.
Simple fix.
This works 90% of the time.
Turn on Laptop. The tiny blue light means it’s on.
Top left corner of the keyboard.
The button next to “Esc”.
Labeled “LCD” - Better known as “F1”.
Press it.
All good?
I hope it was that simple.
I also hope someone at Gateway does the company a favor and removes that button.
crwdns2889612:0crwdne2889612:0 7
crwdns2944067:015crwdne2944067:0:
That worked for me. Thank you so much I can't believe it was that simple. Very appreciative ❤️
I don't know whether to to kiss you or punch my laptop first. You're amazing! Thanks!
It didn't work for me!!!, 🤨😭😒😠🤬
Unfortunately, my F1 is a "Zzz" button. Still tried it, but nope.
I was on my computer and than the screen went blank but shows it’s on so I’ve tried everything in the last 3 hours and it still hasn’t worked
crwdns2934275:010crwdne2934275:0
3 possiblities:
1-bad ram module
2-remove ALL power supply to unit. Battery, power cord. Push and hold power button for 60 seconds. Try it now.
3-bad inverter board or backlight bulb.
One way or t'other, it did work. Thanks.
Well i did the hold the power button down for 60 seconds and was counting to 60 but I only got to 8 when it started to power off then on again so now it’s on and I am going to the same website I went to when it went haywire the website is xfinity. Com but I don’t know if that was the problem
Take the memory out. Mine did the same thing.
Are you saying to replace it ? Or just take it out and try to start it?
@kcitissues
The idea is to reseat the memory module(s) i.e. remove/replace, in case it is a faulty connection between the memory module and the motherboard preventing the laptop from passing POST.
Be sure to disconnect or remove the laptop's battery before removing/replacing the module(s) to avoid damaging them electrically.
I pressed the F1 and it did absolutely nothing. I still have a black screen.
@suejenkins exact model is your Gateway? what are the issues with it?
Engr. Says display IC is bad but no suitable replacement? What do I do?
Ron Hill crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 52,526
