how to fix a noisy fan
One of the cooling fans is very noisy.
I completely took apart the ODD-fan on a 2266 i bought just yesterday with the same problem. 1. there was a tiny piece of plastic caught inside the motor-mechanism - probably causing the noise. More importantly though: There was a massive build-up of rust-dust on both bearings (3x8x4mm), probably originating from the wear of the pin they´re sitting on.
..cleaned it up, gave the pin a little grease, put a spacer between the two bearings (ca 0.5mm) to compensate the weak spring (watch for proper turning-function).
Sounds fine now - hope it will last.
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,384
crwdns2942205:01crwdne2942205:0
All the time or only sometimes? Are the other fans still running or is it just that one?
crwdns2934271:0crwdnd2934271:0 QEII Student IT crwdne2934271:0
