No cellular service after screen replacement.
I recently replaced my screen on the OPO, with much difficulty thanks to the screen being fused to the midbody. When I finally got things back together I realized I no longer have a cellular signal. I'm fairly certain that I reconnected all of the ribbon cables. I don't see where the cellular components of the OPO are highlighted in any of the breakdowns. Can someone assist with this?
Don't know if you fixed this, but for others who may have this problem, it is the signal cable that is attached to the mainboard. It is located underneath the right bottom corner of the mainboard. it is the first thing you must connect when putting the mainboard back in. Also the battery cover must be on to get a signal because it also has an antenna built in so the little pin heads sticking up to touch the back plate or battery cover must contact the cover. Cleaning the battery cover helps get a better signal.
crwdns2934271:0crwdnd2934271:0 Brian Mazakas crwdne2934271:0
