A guitar shaped controller for Guitar Hero III of the Guitar Hero video game franchise.
Broken Connection - blinking lights
Hi Fellas,
up to now my Guitar worked fine. Just today as I tried to connect it seems to connect as Controller No. 2 but the other lights keep flashing and nothing works.
USB connector is unlikely because my other Guitar connects fine and the Broken one doesn't work with my Second connector as well. So I assume the Receiver of the Guitar.
My Problem is now I found no hint where to look for the Receiver Inside the Guitar. Do you have any Info for me about that?
Thx in Advance.
Bye,
Ferdinand
crwdns2889612:0crwdne2889612:0 8
Ive also had this problem and replaced the 220uF @10v capacitor but it still does not work
I had the same issue. Controller used to work fine, but after a few years I discovered it wouldn't synch. I tried my other guitar with the USB dongle and that synced, so I knew it was the guitar. I replaced the 220uF @10v capacitor on the main circuit board and it fixed the problem.
Probably a good idea to also replace the 47uF @10v too, since the factory components are poor quality.
I replaced the capacitor and the problem persists. Any ideas?
The 220uF capacitor change worked for me. Previously, the LEDs blinked in sequence but never synced to the dongle, but now fixed once capacitor was replaced. Thanks.
It's the correct fix done a few with same issue.. If it's not worked check soldering or polarity or replacement capacitors...
Great! Just replacing the 220 one did the job here! Thanks!
For any chance do you guys have a photo of where the 220 uF 10v capacitor is located ?
Worked for me: http://www.fixya.com/support/t1232769-it...
Hey Ferdinand,
i got the exact same problem.
Do you have any new information or solutions?
Regards,
Henning
i’m having this problem where it flickers irregularly. it’s happening on 2 guitars, 2 sets of batteries, both when the receiver is connected directly to the PS3 as well as PC (no hubs). sadly, i don’t know where my other receiver is.
here’s what it looks like: Guitar Hero 3 controller glitching / random flickering - YouTube
any idea the likelihood of it being the receiver?
More than likely be capacitors in the guitars they are known to fail giving the exact symptom you describe
Capacitors on the les paul gibson model suck jus got one the other day and has this syncing problem what makes this even worse are the screws #0 square like are we serious 🤣
Gardovan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 44,671
