crwdns2934055:0crwdne2934055:0
Won't Charge after keyboard replacement
I replaced the Keyboard on Macbook Pro 2011 13"
After re-assembly it will not charge. The Battery dead, the LED will not show on any charger, and it will not charge.
What could be causing this? Please please please help!
Thank you
check if your magsafe DCin board is well connected to the logic board socket.
Go over all your connections(ors) again. 99% of the time a connection that appears correct or good is not completely seated or locked down.
The other cause could be the reason you replaced the keyboard - liquid spill? - may have caused damage to the logic board or components. Go over the board with a magnifier looking for corrosion (discoloration) or burn marks/swollen components.
If this answer is acceptable please remember to return and mark it accepted.
crwdns2942667:0crwdne2942667:0 710
