New replacement MacBook Pro battery discharging erratically
Hello,
I've just installed a replacement battery (bought from iFixit) for my mid-2012 MacBook Pro 13inch Unibody.
The battery charges up to 84% then jumps to 100%. On disconnecting power lead battery holds 100% for a minute then jumps back down to 84%.
I've done an SMC reset. No difference.
coconutBattery shows the jump in current charge from 5712mAh (fully charged) to 4784mAh (tried uploading images but get a resolution error).
Is this a dud battery. Do I need a replacement from iFixit?
thanks
Mark
Update
January 23, 2015
I'll accept @mayer's answer. After several days testing my MacBookPro *seems* to be performing normally. The replacement battery seems to be ok. However I do have some reservations.
So to recap I reinstalled OSX Mavericks using latest combo update. Did SMC and PRAM reset then did two discharge-recharge cycles. I'm now getting 5-6 hours from a full battery with low-medium use. Time remaining and estimated time to full is generally ok - at least there aren't any big jumps from say 50% to 100% or crashes from 50% to zero.
I'm still getting the impression though that OSX doesn't have a perfect handle on how much charge is on the battery and neither is coconutBattery. Occasionally the machine won't reboot after being down to ~30% charge but I'm not sure whether this is because of heavy apps that OSX is trying to reload after previous shutdown. Sleep seems ok and isn;t drastically draining battery.
As a rule of thumb how much charge can I expect to see lost during periods of x-amount of sleep (say overnight) or from shutdown to reboot (say overnight)?
As a further query the design capacity value from coconutBattery jumps from ~85% to ~96% between and during periods of recharge. Is this normal?
thanks all
Mark
What was happening with the old battery?
Had service warning on old battery
You may need to reinstall your system and/or update your firmware. Here's an excellent question on the problem: Erratic "Battery Charging /Not charging"
UPDATE
put the old battery back in, run Coconut Battery and post your results. Tell us if the battery gives you a red or black X.
OK thanks. I'll try PRAM reset and SMC reset again, then complete discharge/recharge cycles and see what the result is.
I'll reinstall old battery and post coconut results if my first attempted solutions don't work.
@mayer - Went through 1 full discharge/recharge cycle. Following this the battery discharged as expected from 100% without any jumps. However, MacBookPro on standby still drained battery as though awake. I then performed an SMC reset and PRAM reset. Battery use now *seems* to be functioning normally.
Thanks for your help
One further question. On coconutBattery the design capacity reading has jumped from 99% (first start-up after battery install), to 96% (after discharge/charge cycle), to 97.3% (after SMC/PRAm reset), to 96.3% (after a test period of sleep). Is this significant? OSX Battery status still good, operating temperature 25.6degC, discharging 12 Watts at current low usage.
wait. Still not good. Crashed 100% to 50% just now. hmmm
You accepted my answer, did the problem rectify itself?
mruddy73 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,316
