Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Touch ID working but home button is not
Hi,
I'm having an unusual issue with my 5s, as the description says, my Touch ID works without issue, however the home button itself is not working. It gradually got worse, going from working 50% of the time to as it is now, which is never. I'm using assistive touch to navigate out of apps and such now, and like I said using Touch ID now problem. I wondered if anyone has come across this issue before and if there is a fix? (That maintains TouchID functionality). Funnily enough the problem developed one year and two days after I purchased it, go figure.
I would take it to Apple, once you replace the home button touchID is lost, forever
Hi David, I have been into the Apple Store, was quoted £100 for the repair, so wanted to check here to see if anyone had come across this before and if there was a fix (that maintains Touch ID functionality) I know a replacing it (when not done through Apple) will lose Touch ID (which I'd like to avoid). Also should probably note I have tried various resets on the device, pretty much everything bar opening it up.
Hello, has a solution ever been found with this?
Hello,
I have the same problem.
I changed my battery yesterday and now my home button is not working... But touch ID is!
I was thinking to the home button plug, but it seems not damaged... Everything looks ok but it's not working...
Does anyone have an idea?
Many thanks!
plug your charger on your iPhone and keep pressing the charger in the port NOT TO HARD at the same time press the home button.
Thanks for the tip but not working in my case :(
Sean crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,771
