Issue with screen - possible problem with inverter
If you switch on the iMac Mac (G4) and the screen comes on for a while, then flickers, and the backlight stops working resulting in a dark screen is this a problem with the inverter? If so, can I purchase this separately and install it? If so, how do I do this? Any help would be much appreciated!
Andrew
crwdns2889612:0crwdne2889612:0 -1
The iMac g4 had some problems with scuffed cables inside the neck, but the inverter or the ccfl tubes are old - so they can also make some trouble.
i would first check the cables inside the nack - but it's not easy to open it. please read more about the whole disassembling process on: http://dremmeljunkie.blogspot.com - this guy made some heavy modding with his iMacs - but you only need the part with the neck ;-)
andrew crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,132
