The Compaq iPAQ Pocket PC 3830. It measures 8.1 cm by 13.3 cm. It was introduced by Compaq in April of 2000. iPAQ was borrowed from Compaq's earlier iPAQ Desktop Personal Computers. The device used a Windows Mobile interface.
The audio volume is not responding to the volume button.
The volume button appears to be in working condition. It does not appear stuck but it is somewhat difficult to maneuver it. It has a hard feel to it.
That sounds like your volume button is jammed. If you unscrew your device you will be able to see what is jamming up the button. It could just be dirt or a screw that needs to be tightened.
Volume controller works on key pad and key pad made up by carbon which disappear after using it and it breaks circuit which is unable to complete your command. In this situation sometime is works and sometimes not and one day it will fully stop.Its really irritate.
Solution-Simply open Sound track button and try to clean it very lightly because if your are cleaning it hardly all the carbon pasted over there will remove it will permanently damage.
After light clean if its still not work simply replace it with new one. Its very easy to change with the help of heat soldering.
http://i00.i.aliimg.com/wsphoto/v0/10380...
crwdns2889612:0crwdne2889612:0 -1
Sedina Cavcic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 391
