Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
crwdns2934591:0577crwdne2934591:0 crwdns2934593:0crwdne2934593:0
How do I change the sim card port?
Hello
so I just got an unlocked S5 and my micro SD card part to the sim memory card module is working but when I put in my sim card for calls its saying no sim card found and Ive taken it out and put it back in many times. I've also put in other sim cards from At&t and T-mobile (since its a GSM phone) and none works and it says the same thing "no sim card found". So I was wondering if it was just the Sim Memory Card Reader Module and I wanna change it out to test it but I've googled and it only gives me the galaxy series up to s4 when changing the sim card port.
please help me in telling me how to change it out
+1 in need of ideas.
Have the same problem. But my phone get wet and everything else is working. Those white things under battery ended up red so I think there is no use for trying to get it through varranty, or?
Interesting!!! Me too. I have the same issue. Out of the blue my sim reader just stopped working and says no sim card. Frustrating when my phone otherwise is in immaculate condition. I'm really upset about it, but am at a loss. Is this a common issue now that i see others with the same problem
From your description it sounds like the problem is in the SIM Reader Module and not the cards. If that's the case, you probably need to replace the module, which would require replacing the motherboard. There's a guide for that procedure (Samsung Galaxy S5 Motherboard Replacement), but you'll need to acquire a motherboard from somewhere else.
Here's a link on eBay that has the parts you'd need to do the replacement.
When replacing your motherboard, you should also transfer your rear and front-facing cameras from your old motherboard to your new one.
Hope this helps!
Hina crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 8,949
