Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
Is it the resistor thermal fuse?
Hi can anyone help me my heater on my auto Vauxhall corsa d was only working on 4 then it stopped working completely so I brought a new heater motor but now it is only working on 4 again is this this the resistor thermal fuse. please help anyone. thanks kirsty
Hi my Corsa heater doesn’t work at all could it be the fuse if so which fuse is it ?
kirsty, there are two common causes of a heater blower fan problem in the Corsa D
1. Faulty Heater Resistor (Part No. 13248240 ) Usually, it is the thermal fuse on it that fails.or 2. The connector on the wire loom connector can become overheated and melt, causing damage to the loom. So take a look at it and see what you find. My money is on the heater resistor thermal fuse. Take a look on here and here as well. Hope this helps, good luck.
crwdns2947631:0crwdne2947631:0
I had similar problem on a Vauxhall Combo heater which worked only on setting 4. The answer was a new resistor matrix fitted into a connector just behind the heater body. It is tricky to reach but it works on al 4 settings now.
kirsty crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 32,938
