2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Can you replace the battery
Is the battery replaceable over the life of the macbook or are you out of luck when the battery life degrades past a usable amount.
Good question!
For some reason Apple decided to glue the battery cells to the top case in this system.
Apple does not sell the battery pack alone only as part of the top case assembly (P/N 661-6532) which is quite expensive! (around: $180 used & $600 new).
There are a few dealers of the battery unit alone. As reference: LaptopBatteryExpress for around $130.
If you do try swapping the battery be very careful! Make sure the battery is discharged, use a adjustable temp heat gun to soften the glue, a set of plastic spatulas and lastly have a chemical fire extinguisher handy! You may need it if you pierce a cell.
I got one of these in this week with a wine spill. An uppercase replacement part priced out at around $700. I took a hypodermic syringe and filled it with methanol and shot about 3 cc of it around each of the batteries. Let it sit for 10 minutes and rocked it a few times to get the alcohol as deep as possible. Then I used a putty knife. I inserted it on the outside batteries first from the side closest to the keyboard. As each battery came up I laid it back. It took less than 5 minutes to have the battery out and in good shape. Looks like prices run from $75 to over $150 for replacement batteries. On mine I needed to replace the keyboard but that's another story. I found a new part in China with keyboard for $158. I'll end up with a new upper case replacement and save $525 making the repair feasible. New trackpads are also available on eBay.
crwdns2944067:07crwdne2944067:0:
@Mayer - I hope you blow out the methanol before pulling at the battery. Remember methanol is flammable! You don't want to give the fire extra fuel. But it does sound like a better way than trying to heat them up hot enough to get the glue to let loose. Just be careful ;-}
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Dan, the methanol had very little liquid residue as it evaporates very quickly and has no water in it like rubbing alcohol. When burning in something like an alcohol torch it doesn't sputter. It can be obtained at dental supply places. I did not know if it would work, thus I didn't take photos for a guide. But this method will make a lot of the newer machines repairable. The iFixit team took 30 minutes to get their battery out. Mine came out very clean and is totally reusable.
Do you want to post something over in Meta so the IFIXIT gang sees it. Good tip! I don't currently have too many retina systems to work on here. But the next time I have one which I need to pull the battery I'll give this a go!
I will do it.
Thank you for this, this was very helpful information.
crwdns2934275:02crwdne2934275:0
Some nylon string, sprinkled with a generous amount of caution, will do the trick.
Once I removed the right speaker, it only took me 10 minutes to cut the glue holding the batteries.
It is very doable if one proceeds with caution.
Munish Gandevia crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 2,864
