HDD Not Recognized on Install?
Hi !
when i try to install Windows 7 from USB, when i get to the part of installation on you must select the HDD, the list is empty, no HDD found :(
any advice ?
tks
Hi !
any advice ?
tks
Did u format the hdd before trying to install the system? U have to create a partition and format it.
Have you just installed a HDD?
If so, is the hard disk plugged in, both power and data cables? Most modern hard disks use SATA cables; see this page on Wikipedia for pictures.
yes !
but i solved, i've used another HDD that was reconized, then after install i've cloned the HDD to the one that wasn't reconized and solved the issue :)
crwdns2942667:0crwdne2942667:0 427
