The Trek 4300 is mountain bike released by Trek in 2003.
What is the psi recommended for pumping up the tires?
I know road bikes need like 100psi, but since this is a mountain bike what should I pump them up to?
The recommended psi for the tires on this bike is 40-65 psi. This can be accomplished using a standard manual bike pump or a compressor with a bike attachment. It is important to check the psi of your tires after inflating them.
Look on the sidewall of the tire.
Generally mountain bike tires have a lower pressure than a road bike, but it is important to read the specifications stamped on the tire. Also, if you are riding on the road primarily, you might want a higher pressure to fight rolling resistance.
If you are riding loose dirt, mud and that sort of thing, you might want a slightly lower pressure than what is listing as MAX on the tire. This will give you a better handling bike.
If you are riding a mountain bike on pavement, use slicks or semi-slick tires. These usually have a higher pressure. The specifications depend on the type of tire, and terrain.
The Standard For City/Not specifical User ist 4 bar,means (59) 60 PSI.
For Offroad use ist round 30 PSI.
BUT EVER SEE BEFORE WHAT IS ON PNEUMATIC SEITE,because Here ist exactly specifical Presstüre dir Tour Tyre.
Jimmy Todd crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,127
