Stripped Screw on Antenna Plate
So just as the description says, when putting one of the hex screws back in on the antenna plate, I over tightened and stripped one of the screws. And when I say stripped, I mean I stripped the threads, the screw just spins now and doesn't hold, it just falls out. Is there any solution for this?
Were you able to solve this problem? I'm having the same issue
Usually it's possible to grab the screw with a pair of needled nose pliers. If not, you might have to drew the screw out using a drill.
Hope it helps!
There's some really cool pliers designed for just this problem!
Screw Extracting Pliers
crwdns2886500:0Pliers designed to firmly grip the heads of damaged screws. Specially designed jaws firmly grip screw heads, bolts, or nuts allowing you to twist out even the most damaged fasteners. Professional Grade tool. ESD-safe option.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
Its not the hex part thats stripped, its the threads female threads that are stripped.
To get it to hold back in place, you can always try using some Loctite or another type of threadlocker. Just don't get the super high strength stuff, or you'll do more damage.
Thats kind of what I was thinking...Guess I'll give that a shot.
Were you able to solve it? I have the same problem
betts211 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 439
