Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
Ice is forming on inside bottom of freezer/side by side
Ice is forming under the bottom draw of my freezer in my side by side fridgedare side by side model. It then leaks out door onto the floor. Any help would be greatly appreciated.
There is a drain in the back of that area that may be clogged. My mother in law has the same issue and I hope to try and fix hers in the next couple of days.
I found some information at http://www.justanswer.com/appliance/85hp...
paul turturro crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,063
