My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
crwdns2942667:0crwdne2942667:0 1,677
