Why is the trigger jammed?
My trigger will not move back when I try to pull it. It feels stuck and performs as if it has not been cocked.
The trigger could be jammed for two reasons. Either a disc is lodged in the barrel or there is dirt jammed underneath the trigger. In order to clear the lodged disc, pull the barrel slide located on the top right hand side of the gun with the gun barrel pointing down. The disc should be released and the trigger should pull back. To clear the dirt, you will need to take apart the gun. Clean the dirt with a toothpick or cotton swab. For more information, reference the Troubleshooting guide. You may also need the spring replacement guide.
Did you copy this from Google?
Look at the date of the post. You may be waiting a while for an answer
The link is to an ifixit guide created in 2014
Moderator
crwdns2942667:0crwdne2942667:0 6,625
