The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Why is my xbox stuck on green light and not booting?
my xbox is stuck on green light not red. but it wont boot. it happened when iwas playing GTA 5 for 5 straight hours. the suddenly the screen freezed. i tried to turn it off then when i turn it on. it only turn on in green light but no signal to my screen. i tried to take it for repair. the repairman tried to reball it but still nothing happened? what do you think is the cause? and the best way to repair it?
crwdns2889612:0crwdne2889612:0 7
the same thing happened to me
It sounds like a display connection issue. The xbox usually won't start if there isn't a display signal. Check your hdmi cable. Try swapping the port it's connected to on your TV. If you have another HDMI cable, try using that.
i tried it sir but still nothing even the controller wont sync.. and also the repair man, added that the cause might be a dead cgpu chip.
Dear you should screw out the xbox and reconnect the fan inside and it will work....
first of all your console is old version so try to nand x reinstall in your console .
if then not working so try to use heat gun on your console board
best of luck!!!!!!!
i have a similar problem. ?? Any updateS?
zhedsn09 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 11,521
