Keyboard does not show when trying to add a new contact.
When using + to add a new contact, cannot get the keyboard to show so I can't type in the name. Is there
some setting I need to change?
'''A hard reset can cure some of the problems.
I found that if you have bluetooth enabled - it is trying to reference another device.
Go to settings - turn the bluetooth off.
Restart the phone and problem should be resolved.'''
Yes! it works! thanks :))
I'm having the same problem with iphone 5
I posted this question. The Verizon store did a total turn off and then restart by holding down the sleep/wake button at the same time as the button at the bottom of the screen. After a few seconds they turned it back on and when it booted up the problem was fixed.
Trying it now on my iPhone 6 ... It worked! Thanks!
Awesome fix, thanks!
It works, thanks
Thanks It Works !!!!! jmc
Thanks! turning off the bluetooth and then restarting the phone worked for me!
I told it to Siri and it was fixed asap!
Turning off phone worked for me too!!
I have Reboot my iphone4s it worked for me..Thanks for the answer.
How can I get key board to appear when I am trying to type in new contact
Hi - I had this problem on my iPhone 5s. I tried to fix it several times by turning the phone off. That did NOT fix the problem until I first turned off Bluetooth. Then it worked. Thank You!
I had the same problem. All it took was shutting the phone off, waiting a minute and turning it back on.
Thanks! Restart worked!
I can’t add a new contact in my iPhone because the keypad is not showing. What is happening?
You might also have this issue i just experienced. Double click your home button and if there is a blue-million windows opened, then close them all. For some reason it seems that there is a “Limit” as to how many windows can use the keyboard at one time. Not sure what that limit is, but if there are too many windows opened, you might lose some functionality.
Good Luck!
Turn off blue tooth and reboot. It works
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 38,566
crwdns2944067:06crwdne2944067:0
Tap on the word 'Name' and the keyboard appears. Same for number, tap on the word phone or number and the number keyboard appears. Too simple for the experts to answer.
crwdns2934271:0crwdnd2934271:0 Mal Walker crwdne2934271:0
Thank's a lot a have the same problem too
crwdns2934271:0crwdnd2934271:0 Ivette Carlier crwdne2934271:0
Problem is not solved with above answer.
crwdns2934271:0crwdnd2934271:0 Lee L Weber crwdne2934271:0
ditto
ty for the obvious answer on how it should work however when one speaks of an iphone 5 you can reasonably assume that there may have been a few hundred times that it has functioned as designed and that these queries are not the result of an extremely loud and belligerently aromatic brain fart.
Too simple for experts to answer?
Thanks for the case in point but it wasn't the question or answer that was simple.
crwdns2934271:0crwdnd2934271:0 jorkvilleyoe crwdne2934271:0
Using the information above re: tapping on name etc. I got keyboard to show. BTW I experienced this issue right after an update... JLJ
crwdns2934271:0crwdnd2934271:0 jejo46 crwdne2934271:0
