The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
galaxy s2 shows battery with yellow triangle
galaxy s2 shows battery with yellow triangle.
I have it charging right now. I changed the battery once but a few days later it shows the same thing. Can the replacement battery be bad as well or it a different issue?
Also happens in the beginning when the battery wasnt charged for a long time but in this case the symbole disappeares after a few minutes.
Try a new battery if you still have the problem it's the charging port on the phone an you will need a new1 soldered in
can it be a software issue where i have to use odin?
Subba crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,792
