in response to vapidmorris: When my G4 starts giving me warnings that my clock has reset, I take a 48hr block of time when I can leave it in the off position, plugged into a power source, with the rechargeable battery REMOVED. This is important because while that battery is still in it is going to suck up every bit of power that comes into the machine. If you remove it, then all of the power goes straight to the internal battery and reconditions it. You'll notice that it will boot up faster, and find things in searches much faster than it did before. It's not important that all 48 hrs be uninterrupted. But you should try to give it at least the first 24hrs and then just remember to set it up every night before you sleep. until it reaches a total of 48 hrs. After this attempt to recondition the internal (pram) battery, if it still gives that warning after removing all power then the pram battery needs replaced. But it's always better to try this first cause they can be a pain to get to. Hope this helps!
Teresa
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
