iPhone Stuck on Apple Logo
I have tried the hard reboot and then holding down the volume + and power button but it still doesn't seem to work. Not sure what's going on.
Try a new battery iPhones won't boot past apple logo if battery is faulty
Will a new battery restore the phone?
No won't restore it
Okay, Thank you
I cannot open my iphone 5
Don't worry, just follow these steps to fix iPhone stuck on Apple logo
=> First of all Start your Computer and then connect with Internet connection, now Download the latest version of the iTunes application
=> Now install the iTunes application in your System and connect your Device with computer via Data cable
=> Now connect your Device with iTunes application and then Tab on summary option, see in the left side bar of iTunes
=> Now Select restore option from iTunes and then confirm the Restore Message for better results. After this unplug your Device and Restart it
I hope that will surely help you with iPhone Data Recovery.
Thank you...
Did you even bother reading what the OP said?
Dude above me has very wrong information. Simply Promoting own Content i guess.
OP if you still struggling then Go over Here. Exact steps explained which might help you.
Hi there! i just had this same problem, looked on here but nobody would respond. Luckily i have found a solution. I bought a new battery and it has totally fixed the problem. It's worth considering it as they're really cheap and easy to fit.
Hope this helps!!
Jacob
Occasionally through the standard iOS upgrade process, but most commonly when jailbreaking, the iPhone can reboot and get stuck on the Apple logo at boot. This basically looks like the “” against a white or black screen.
Turning the phone on and off generally doesn’t help, as you’ll be continuously stopped at the white Apple logo and the iPhone never boots This is different than being stuck on Recovery Mode, which shows the ‘Connect to iTunes” graphic on the iPhone screen, but can be fixed in a similar manner by using DFU mode and iTunes.
You’ll need a USB cable, iTunes, a computer, and of course the iPhone (or ipad) to complete this job. This requires that the iOS device be restored, so have a backup handy or be ok with installing a new clean iOS.
crwdns2942667:0crwdne2942667:0 20,262
Well, to repair your iPhone making iOS return to normal, you can try using the iOS System Recovery.
iOS System Recovery can one click to fix your iPhone iPad stuck in Apple logo and recovery mode without losing data. You can read more from: https://www.youtube.com/watch?v=xFY_D8kd...
crwdns2934271:0crwdnd2934271:0 caicaiys crwdne2934271:0
