How do I attach a replacement battery?
3 tiny male connectors stayed attached to the old battery, therefore i need to know if i must solder? glue? or somehow attach the battery cable to the board to make a permanent connection
crwdns2889612:0crwdne2889612:0 -1
Assuming you don't break your display while detaching the battery from the display assembly, you will need to de-solder the original battery from the logic board and solder on the replacement.
Hope this helps! Good luck!
ken crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 379
