Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
3GS cracked screen. Do I need the lcd too?
My 3GS screen is cracked but I can still see all my apps, use them, make calls, etc. Can I replace just the digitizer glass? I bought one on ebay for about five dollars but worry now that I may have bought the wrong thing.
crwdns2889612:0crwdne2889612:0 -1
you can buy a replacement digitizer with frame and use your original lcd... Remove the screen by following a guide from ifixit.com, unscrew the lcd from the frame, put it in the new frame, connect the connector back to the logic board and gently push the screen back down, put the 2 screws back in the bottom and your done.
if you have only the glass digitizer it will be more of a complex job as you will need to remove the old broken digitizer from the frame which is stuck in with adhesive.
I personally would recommend you buy either a new frame and adhesive and stick the new digitizer into the new frame and transfer the proximity sensor over to the new frame or buy a half front assembly for your iPhone which will be everything apart from the lcd.
Heres a guide incase you decide to do the more complex job - iPhone 3G Front Panel Replacement
and heres a guide if you decide to buy half front assembly - iPhone 3G Front Panel Assembly Replacement
just follow the second guide in reverse to once disassembled your device to put the lcd into the new frame.
crwdns2886500:0iPhone 3G Front Panelcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
crwdns2886500:0iPhone 3G Front Panel Assemblycrwdne2886500:0
crwdns2937801:0crwdne2937801:0
45 minutes - 2 hours
Many thanks, Alyn!
Brooke crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 71
