Why are there horizontal lines randomly showing up on my screen?
I bought my MBP back in 2012 and I haven't had any problems since. However, this past week has been really trouble some as it didn't want to turn on at all at the beginning of the week (this was fixed by unplugging and plugging back the battery connector).
Last night I was using my laptop and all of the sudden weird horizontal green lines appeared on my screen (photo 1) after I had carried it from one place to another. I had to press and hold the power button to restart the laptop as the computer was not responding to my finger on the trackpad.
Later on last night I was carrying it again and I noticed that when I held it on the left side (photo 2) the screen started doing that funky thing with the lines. So I restarted it again.
Now I am avoiding holding the laptop on that side, but anybody have any idea what is the problem and how can I fix it?
Please note that I do not have Apple Care.
crwdns2889612:0crwdne2889612:0 7
I've tried resetting my PRAM as I did some extensive research regarding the matter...but it didn't seem to resolve the problem.
UPDATE: It seems as if it doesn't matter how I hold the laptop -- If I hold the laptop with a single hand on the left/middle the lines appear and it freezes my laptop... ALSO the lines done appear the same all the time but they are always horizontal...
i have a similar problem but it doesnt freeze when i hold my laptop a certain way. they seem to just show up and either go away on their own or I have to reposition the laptop to get the connection back with the display to make them disappear. it's only temporary (literally only a few minutes) and it comes back again. theyre just random tiny black horizontal lines, sometimes it's a lot sometimes it's only a few, but no one seems to have a definitive answer. i tried doing the whole PRAM reset but my laptop will literally just switch back and forth from gray to black and not turn on. so i turn it on normally and nothing changed. ive tried this several times. im guessing at this point it is a hardware issue but i want a second opinion before i call anybody. please help, this computer is so much money and i need it for my schooling. im on winter break so i have until then. thank you!
crwdns2933315:06crwdne2933315:0
It looks to me like a gpu (graphics processing unit) error, In some macs this does happen and we have had many macs thought our doors with this error, the only way to fix this error is to remove the gpu and re-ball.
the error is normally caused by excessive heat but can just happen for no reason at all.
I'm not sure where you are located but we are located in the uk.
You have 2 options to get this error fixed:
option 1 - find a logic board specials and and tell them you need the gpu removing, re-balling and fixing back to the logicboard.
option 2 - book a genius bar appointment and let apple get it repaired or replaced.
option 2 will be by far more expensive.
sashasmaili, the very first thing you want to do is to connect an external monitor. Should this show the same issues then you know that you have GPU problems. This could be repaired by either having a professional reball or at least a reflow done. If your external monitor is okay, then you know that you are having LCD issues and you should consider replacing the LCD. Hope this helps, good luck.
crwdns2942205:01crwdne2942205:0:
Oldturkey03, thank you for your advice -- sadly I didn't have an external monitor to connect it to in order to test. Hence I took it to a tech he automatically assumed that it was the graphics card but he soon realized that that was not the case. He opened up the laptop and checked for any loose connections, but with no luck. There was this foam like thing that was pretty much falling apart on the back lid which laid on top of the RAM, he said he had never seen a model with that foam there (he then realized I had an US model and not a local model (Thai)) he decided to take off the foam as it was falling apart anyways. He then tested to see if the problem had been solved, and sure enough I haven't had any problems since. Funny how something so minor that has been there all along (he actually thought I put it there) could create trouble after over two years. I'm keeping my fingers crossed, hopefully nothing bad happens anytime soon.
i hv the easiest methd fr u , it may wrk , it did fr me :
go to display, color, colour lcd n press calibrate
when it cms to the setup presss continue till target white point , there change it too 9300 even though the screen is a bit diff and this is possibly a temporary fix just try it it worked for me!
Brilliant worked for me too
this didnt work for me
This is a GPU issue. Apple are now repairing all MBPs that have this problem. Book an appointment in the Genius Bar. I had the same issue with a MBP2011 and they fully replaced the entire thing for free!
Hi having read endless fixes for this rolling screen issue which I have suffered from for months , this USB how I fixed the rolling lines and flickering screen at no cost, simply plus in a monitor or tv screen through the hmdi or USB socket on your MacBook share screen and it’s fixed the issue, hope it works for you !
Have you tried to remove the RAM module from the lower bracket and restart your laptop with only the RAM module in the upper bracket? It is a known issue on this laptop.
sashasmaili crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 137,275
