The Samsung Wave II S8530 (or "Samsung Wave II") is the Successor of Samsung Wave S8500 smartphone running the bada 1.2 operating system designed by Samsung, which was commercially released on October, 2010.
The glass is broken but the image on it looks perfect
I have a wave 2.the glass is broken but the image on it looks perfect, with the same colors. And the lower right corner touch screen still works.if i separate the glass from what you call digitizer and mount it back on the phone i will be able to use it without the glass? And the touch sreen will work anywhere too?
silviu, most likely not. I suggest that you replace the complete assembly. this has a higher rate of success and is a lot easier. For instructions check on here. The assembly is widely available at multiple places , depending on your geographic area. Hope this helps, good luck.
The price difference is very small. For people without experience, this operation is dangerous (digitizer and LCD display separating).
absolutely agree with you. That is why I recommend a complete assembly, it is a lot easier and does not require a whole bunch of tools etc.
silviu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 585
