Hello,
You should take the battery out of the thing its in, (if its still in something) and then put the battery in water if its hot. If the battery is not hot then you should check for holes. If there is a hole, clean up the hole on the battery with water on a cotton rag, then you should put the battery in the recycling. It is not safe to reuse a broken battery as it could catch on fire or explode. The smell you are smelling is also toxic so I don’t recommend smelling it over and over.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
