Why is ac blowing warm air?
My 2004 Acura MDX is blowing warm air. Sometimes the air will be cold and sometimes not. I haven't checked the freeon levels yet. What could be some other causes?
Josh, bad compressor, bad evaporator, leaking condenser, bad fan etc. So there are quite a few things that can go wrong. Start with the simplest of all, have your refrigerant checked and refilled if necessary.
test the Clutch relay by swapping it with your headlight relay (same part) No headlights = bad relay.
Josh - just had the same problem. Tried to fix it myself with a "do it yourself" refrigerant charge. No use. Finally took it into the local repair shop and it turned out that the refrigerant tube between the main unit and the rear heater/AC console was "corroded and worn". Anyway - $750 and 2 days later and I had cold air!
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 18,826
