Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
Need wire terminations inside the volume control circuit board
The wire between the volume control circuit board and the xbox got pulled out right at the solder joints inside volume control circuit board. I can easily reattach them but don't know the exact sequence to put them back. Looking at the board I can see the following identifications on the terminals. G, V+,M+,R,L.
Wires I have to terminate are a Common Ground, Red, Blue, Green, Green\white stripe
I can tell from what is loft on the solder joint where the Common ground (G) and Red wire (R) land. Just having problems with the other three wires.
Any help would be appreciated.
I need to see photo of Razer Kraken Pro V2
Volume control circuit board
Same issue wires pulled off - just need to know which wire goes where
If someone can provide photo pls
Michael Howe , not the greatest of all descriptions, but this is what I have
Green
Red
Green/Copper striped
Blue
Copper
If you need to know where each one connects to on the other end, I can check on that in the morning. Hope this helps, good luck.
Michael Howe crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,346
