Repair information and guides for the Apple Mighty Mouse. This mouse is equipped with a laser sensor, four buttons, and a trackball.
scroll ball only works in one direction
I have a mighty mouse and the scroll ball only works in the right to left direction. In older mechanical mice, every so often you needed to take the ball out and clean the wheels that the ball touched on the inside. How can I safely take the cover off the mighty mouse and check to see if the inside needs cleaning?
crwdns2889612:0crwdne2889612:0 -1
There's another answers topic on this subject here.
First, try a lint-free cloth with a little isopropyl alcohol or similar on it and rub the ball with it in all directions for a while. Works nearly every time. When my mouse acts up i'm sometimes a bit sloppy and just rub it over my trousers which works just as well.
Eventually even the trouser trick wont work. Follow these images to see what you need to do. Its not that hard, but you need a little glue when you are putting it back together.
http://www.applematters.com/index.php/ga...
use a vac over the ball
Paul Watson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,056
