Brother Printer MFC 255CW Black ink won't print?
I haven't used my printer for some time so the cartridges had dried up. I was advised to soak the black cartridge in warm water for a few minutes which I did. It still didn't work when I reinserted it so I bought a full, new set of cartridges (not Brother!). The other colours are fine but the black won't print at all, not a glimmer.
Brother have said they can't help because I haven't used there cartridges.
Is it time to throw it away?
Any advice will help - thanks you
My Brother printer is brand new out of boxits a year set in garage now took it out put ink cartages in it but run it a lot still no ink on pages
I also took ink cartages out of packaging they were in put in printer and run it no ink on papper I used note book papper with perforated lines tour out of spirol not book and run printer at least ten times no ink ont the note book papper I removed ink cartages some had ink on nozel ends I put my finger on cartage ends some put ink on end of my finger put back in still don't print and it's brand new I took it out of box any ideas please let Me know.
1.) Press and hold the Home button for 7 to 10 seconds until the touchscreen display changes to show the Serial #, ROM Version, and Printed Pages.
2.) Press and hold in the blank rectangle displayed under 3. Print Page for 2-3 seconds.
3.) This will change the touchscreen display to a keypad.
4.) Using the numeric keypad on the touchscreen display press *, 0, # in that order. The touchscreen will display '0 Maintenance' in the top left corner.
5.) Press 7, 6, 4. The top left corner will change to 'uINIT_P ALL'.
6.) Press the Left Arrow at the bottom left corner until the display changes to show 4 arrows on the top row of the chart.
7.) If the affected color is only Black, press the ◄ or ► key on the top row until the display changes to 'uINIT_P BLACK'.
8.) Then press Mono Start on the touchscreen to begin the User Reset Purge.
crwdns2889612:0crwdne2889612:0 14
crwdns2944067:016crwdne2944067:0:
This definitely worked! The black wasn't even showing up on my print quality check sheet. After I did this, it showed up but with gaps so I had to clean it again. Thanks so much, it was driving me NUTS.
This worked!! Thank you so very much. Genius!
By the way, this was on my Brother J4420DW
I just created an account on this website for the sole purpose of thanking you @vannoi! Thankfully I know that when a Brother printer tells you it won't work, it's often lying, so I knew to persevere on finding a solution to my new black ink not printing. You were one of a very, very, very few people who knew and posted the solution to this one. Now I don't have to put my foot through my printer...although I may just to teach it a lesson. Thanks again.
Worked fine on J6920DW - many thanks.
crwdns2934275:011crwdne2934275:0
First step is to see if it will print a test page
Go to Start, settings, printers. Right click on the printer, properties, print test page.
If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
Next would be to make sure the contact points are clean, take a q-tip and some rubbing alcohol and dab the contact points to ensure they are clean.
Thanks for responding. I've already done the head cleaning process more than half a dozen times but it makes not a jot of difference. Test page prints fine in other colours but no black!
I'll try cleaning the contact points - can I use white spirit?
It worked, thank your the best!
@Christine Hurst Try This:
Absolutely brilliant! I too had tried everything recommended by Brother, and nothing worked. This did, it was fantastic. Thank you so much!
No matter how long I press on the “Home” button the display screen never changes.
Christine Hurst crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 19,115
