Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Spilled coffee on it
I spilled a coffee on my mac book, I just want to know how I can clean it up.
thanks
Do you mean iBook G3 12"? Look immediately under the display, it will say iBook
He specifies 12'' so i'd assume iBook
Sorry to hear that! The most important thing, if it is still wet, is to absolutely avoid turning it on. I would follow the iFixit guide for MacBook topcase replacement, and open it up to the point that you can get inside the main part of the laptop. I generally use q-tips dipped in rubbing alcohol for cleanup. If the keyboard got wet, it may still end up working, although sometimes liquid-damaged keyboards have a "crunchy" feel from that point on. If a key is particularly bad, you can literally pull the key off, wipe down the components with cleaner or alcohol, and snap the key back in, and that sometimes helps, but the grimy residue that coffee and soda leaves is not easy to be rid of, which is why I'd recommend popping the topcase now.
Again, it's VERY important that it is completely dry before risking turning it on. If there is any doubt about liquid still in the machine, let it sit for a couple days if necessary.
Whoops, I just realized this may be an iBook, not a MacBook. In that case, I'd follow the iFixit instructions for removing the battery, and getting inside the memory compartment, and clean out as much as you can reach from there, and then let dry. You can do more surgery if you're up to it by following the iBook hard drive removal guide until you have the machine open, but opening an iBook is considerably more difficult than popping the top on a MacBook.
You need to take apart the iBook or Macbook as much as you can to clean the coffee on the internal components. The best is to dismantle the machine and clean the logic board with rubbing alcool as suggested by rdklincorporated.
Maria, there are many threads concerning liquid spills in the two forums here. Just do a search for "spill" and "liquid" and you'll find interesting answers about this problem. Good luck !!
keep the iBook in heat of sun light 4 to 5 days and clean the system
coffee should be dry and remove the keyboard and check the it that the liquid dry also pass the current to another component. After this you on the Ibook
No, that might damage some components, best to leave it in a bag of rice.
Maria Obrador crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 3,789
