Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
will not turn on after digitizer replaced and blue sceen
after I replaced my digitizer I was able to turn on my ipad by connecting it to my laptop (power button doesn't work I believe I damaged the cable ) in my attempt to disconnect the battery leaving ipad on I disconnect the 3G cable causing screen to go blue then black with some long paragraph blurred and shaking across lcd that I couldn't read and then I disconnected the logic board cable the logic board cable . after reconnecting everything and plugging ipad to iTunes it will not turn on and doesn't recognize in iTunes as a device. so besides damaging the power volume cable and accidentally breaking the speaker box adaptor off logic board , I now damaged something else I don't know where to start and replace . worst decision to try and fix my ipad ever but please don't be sny I just need advice , thank you in advance !
crwdns2889612:0crwdne2889612:0 -1
answering my own question I found out that it need to completely run out of battery and then after replugging it back in to charge it was able to turn on, I assume it internally froze and needed to reboot. so now I have my lcd back just need to fix my other two issues which require parts.
Liz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 177
