R Cuthbertson, "but it is so faint you can hardly see it" would be an indication that this is not a screen error but a backlight issue. Since your device suffered a "liquid spill" I strongly suggest that you disassemble it, and clean it properly with some isopropyl alcohol. Take a good luck at the LCD connector, check for corrosion, any loose, missing or burned component. The Macbook use a LED backlight and as such has a LED driver circuit, pay close attention to that. Double check your serial number, the one you posted does not yield any return for me. I suggest that you do not purchase any parts until you properly identified the real issue. Hope this helps, good luck.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
