Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
iPhone ringer wont switch to vibrate stays only on ring?
My iPhone ringer switch stays on ring. I switch it back and forth and it stays on ringer it wont swtich to vibrate? I was wondering what specific part on my switch was bad?
I pushed my vibrate button from side to side and it won't vibrate my phone
crwdns2933315:07crwdne2933315:0
I'm having the same problem, looking through other posts with similar issues, it seems to be either a loose connector, should be #5, or the headphone jack assembly, it includes the volume switch, the silent/ring switch, the headphone jack and the lock switch. I took mine apart and didn't seem to be a loose connection, everything else on that cable assembly works fine, thinking it's the switch, but I have to buy the whole assembly to get it....
EDIT: I took mine apart again and messed around with it some, it's not a loose connection, it seems the switch is shorting out or is warped just enough to prevent the required conections from being made inside the switch to go into silent mode. if I take a screwdriver and put any kind of pressure on the switch with the phone apart, it goes into silent mode. I didn't have time to mess around much with it. I got it from not working at all to back to needing alittle pressure under the switch on the outside to go into silent mode, sometimes it stays, but most of the time it doesn't. You would think a case that protects the phone when it's dropped would lessen the effects of the fall enough to keep the switch from warping/breaking but I guess it doesn't. Going to mess around some more later on and see what I can figure out, not ready to spend $50 on something if I cna possibly fix it....
I had a similar problem with my 3GS
What I noticed is that if I switch it to silent and push the silent button very little upwards (towards the screen) it stays in silent. So I just put a bit of hot melt glue (less than 1mm) on the bottom of the switch to pad it up a bit.
It worked for me, hope it helps.
Replace the headphone assembly.
The Same prob i am facing so what i did is just went to settings and done vibrate off that is what the solution i found to avoid it.
I had the same problem just go to settings, sounds turn volume down and make sure vibrate is on. You could also turn vibrate off if you want silent!
I'm having the same problem ): my switch doesn't work neither does the the lower volume switch but to turn the volume up it works. I start a new job soon and can't have my phone constantly ringing while I'm working. Any help??
my i phone 1 is automatically going into silent mode. don't know what to do.
Corde crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 27,541
