The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
Samsung Galaxy Ace Plus is shutting on and off by itself?
My phone ran out of battery and I put it to charge, after charging I turned on the phone... The phone shows Samsung, then the model and shuts off by itself and goes on a loop of turning off and on.
I thought it might be the battery so I bought one... Same thing happens when I installed the new battery, then if thought it might be that the phone doesn't charge so I bought a battery charger to proof that theory. I charged the batteries only to discover that the phone goes on the same loop of turning on and off by itself. Does anyone have any idea what can it be? Thank you for any help you can give me.
My phone turn off that day and wont turn on until now . But when i try to start , it only came out the battery symbol and keeps vibrating .
My samsung galaxy J1 ace also had the same problem what should i do?
Yes A solution is present if your mobile memory is full then it starts on and off and to solve this problem you can reset the mobile by pressing home button +volume up+power button and then reset the mobile from there and then mobile will work normall as it is...thankyou
crwdns2933315:06crwdne2933315:0
Hold down your power button + your volume up button. Continue to hold maybe, 25 - 30 seconds? To my knowledge, that'll reset the device. if that doesn't work, I would try getting into the 'recovery menu' and restore your device that way.
Yes a hard reset fixed it! THANKS
I have also had the similar problem. Phone was fine for 12 months or so that I have had it but then it did an
Automatic software update and I have had the problem ever since, about 2weeks onow.
One of the 2degrees guys suggested that the new software was not compatible with this phone. Typical android which is why IOS has it all over them.
Colin
itself off and on
how to fix ace4 itself tuning off and on
I have the same problem, my phone is stuck in some type of restarting loop. Its not the battery that is the problem with me either and i haven't come into contact with water, I've seen people talking about a power button problem, I asked a question about it hopefully it gets answered
My phone did come in contact with water
It blowed an IC
I dont KNoew wht is up
Same thing with phone i have, wont stay on
my problem is ,it power its self off and on.even if i try touch on the scrn ,it goes off Galaxy [ace 3 samsung]
I have a Samsung ace 5830i that when goes into sleep mode it turns it off completely
Olyme crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 11,311
