My microwave has been acting up lately, starting on it's own after time was up and other weird things.
Took it apart, tightened all ground screws and put it back together.
Same problem. I then started it and held the door frame up a bit at the bottom opposite the hinges.
It worked perfect, the switch was now making proper contact.
On my model on the bottom of the door there is a steel bar mounted to the chassis by two screws with a hole that mates to a pin on the door for opening. I installed three small washers on the pin which forced the door up at the closing end.
It works fine now.
DB
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
crwdns2944067:04crwdne2944067:0
Microwave runs but doesn't always heat? Is it the door?
crwdns2934271:0crwdnd2934271:0 l.b.lewis crwdne2934271:0
My over the range microwave shows error “door” and does not turn on. But after repeated pushing the button it does. Any help.
crwdns2934271:0crwdnd2934271:0 Arijeet Sengupta crwdne2934271:0
I have this issue also. Mine will also turn on the light and start running with no time on the clock! I will never buy another LG. I had a Panasonic for 18 years (i got it as a wedding gift!), then bought the LG and have had it only 2 years.
crwdns2934271:0crwdnd2934271:0 Phil crwdne2934271:0
Knowing others have the same issue, item should have been recalled or customers should have received a replacement part. Over time, technology should get better, not worse. So my old unit lasting 18 years shows true quality and workmanship.
